75 fuel pump in 73 location. Needs some advise, Captn? anyone whom might have some suggestions |
tod914 |
Jan 9 2010, 02:19 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
I just roughed out the placement of the 75 pump in the 73 stock location. Not the best fit. One problem the fuel filter can't be secured in the 73 filter holder. I also think the plastic lines might have to be trimmed. You guys have any suggestions? I'd rather not move it up front. Capt'n is this the way you have done it? Thanks for the help.
914_teener |
Jan 17 2010, 10:35 PM
914 Guru Group: Members Posts: 5,255 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Ok,
Finished today.....long day. Replaced the old pump with a later model fuel pump and placed it in the firewall area. Did lots of other maintainance stuff as well. Biggest one was the gromment ......or lack of one, where the accelerater cable passes through the tin had worn out and cut into the sheath. So what the hell...replaced that too. My biggest fear was after taking most of the top end apart, old lines and what not, and it would not start. Hit the key after priming the pump and .....started right up and idled perfect. (IMG:style_emoticons/default/driving.gif) Now gonna put the new rims on! I decided not to go too far and save some energy for the 2.0 at the end of this year. |
Lo-Fi Version | Time is now: 5th February 2025 - 02:33 PM |
