Questions for a 3.0, #1 is adapting to a 901, What can I keep, what do I need? what else? |
Mark Henry |
Dec 27 2009, 09:20 PM
Still debating to build a 2.0 or 2.4 or 2.7 or say fuch it sell it all and get a 3.0 (IMG:style_emoticons/default/confused24.gif)
To me the bottom line $$$ looks almost the same. For a 3.0: What would I need to keep for the clutch and PP (9bolt fly) that works on a 901? What would I need to buy from KEP? Should I be grabbing anything else from the donor engine ? I'm looking a a few engines, #1 a 3.2 that's a bit beyond my budget, #2 an unknown 3.0 longblock core, spins fine, I suspect a broke headstud(s) #3 a good used stock 3.0 euro sc with CIS, #4 a hot rod 3.0 with webers newer top end w/JE's I'm reading all the pro's and cons, yes JP.... Santa did bring me Wayne's book (IMG:style_emoticons/default/smile.gif) What would be your order on my engine choice list above? Cheers (IMG:style_emoticons/default/beerchug.gif) |
sixnotfour |
Jan 20 2010, 01:41 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
poke a screw driver down to the throw out bearing pushing on ears of bearing housing and it will rotate free from the arm. 70-71 only
SLITS |
Jan 20 2010, 05:46 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
poke a screw driver down to the throw out bearing pushing on ears of bearing housing and it will rotate free from the arm. 70-71 only What "That Guy" said is the correct way. There should be holes in the bell housing to be able to stick the screwdriver through. The circlip goes around the base of the TB ... hell to get at, but that's what holds the shit together. It looks like a round wire. Was gonna modify your photo, but it turned into a clusterf__k uploading so I gave up. (IMG:http://www.rccauto.com/engine/901-911.jpg) Ok, so I tried again. And I'm still amazed that you could get at the ring gear/clutch plate bolts to remove the assembly from the flywheel. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:51 AM |
