Buick/Rover aluminum v8 to 914 conversion |
streetrover |
Dec 22 2009, 09:30 AM
Member Group: Members Posts: 87 Joined: 22-December 09 From: Inland Empire Member No.: 11,163 Region Association: Southern California |
Hello everyone! OK, I've got an empty 914 in my driveway and a 4.0 liter Rover engine in my garage. A Buick 4bbl intake is en route as is an Edelbrock carb. I've got lots of questions about clearance, most notably about the distributor. The Rover engine came stock with a "crankshaft angle sensor" and individual coils. It'd be great to use this instead of the distributor but I don't know if I can run this ignition system without the "computer" that also controls the fuel injection. If I need to go with the distributor instead that's fine but then how do I overcome clearance restrictions? I would REALLY love to talk to someone with this conversion completed!!!
Thanks, Bob |
914GT |
Jan 20 2010, 08:57 PM
Senior Member Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Dave,
I know nothing about the Rover engines, but if they are prone to leak from around the oil pan you may want to set up your stand to match the angle when engine installed in the car - if that's possible. My chevy motor does not set level, with the front of the block lower than the back. And my suspension and wheels have the rear of the car just a bit higher than the front. Hence there's more oil in contact with the front pan gasket, resulting in a little seepage from that area. Just something to consider. Guy |
Lo-Fi Version | Time is now: 27th December 2024 - 04:51 PM |
