> Questions for a 3.0, #1 is adapting to a 901, What can I keep, what do I need? what else?
Mark Henry
post Dec 27 2009, 09:20 PM
that's what I do!
Still debating to build a 2.0 or 2.4 or 2.7 or say fuch it sell it all and get a 3.0 (IMG:style_emoticons/default/confused24.gif)
To me the bottom line $$$ looks almost the same.
For a 3.0:
What would I need to keep for the clutch and PP (9bolt fly) that works on a 901?
What would I need to buy from KEP?
Should I be grabbing anything else from the donor engine ?
I'm looking a a few engines,
#1 a 3.2 that's a bit beyond my budget,
#2 an unknown 3.0 longblock core, spins fine, I suspect a broke headstud(s)
#3 a good used stock 3.0 euro sc with CIS,
#4 a hot rod 3.0 with webers newer top end w/JE's
I'm reading all the pro's and cons, yes JP.... Santa did bring me Wayne's book (IMG:style_emoticons/default/smile.gif)
What would be your order on my engine choice list above?
Cheers (IMG:style_emoticons/default/beerchug.gif)
Mark Henry
post Jan 20 2010, 10:42 PM
that's what I do!
I know how it comes out normally, I did remove the exact same type of clutch at the clinic last fall. This PP is pinned to the bell housing, you can't spin the PP. The release bearing is pined as well so I cant just spin it with a screwdriver.
Ron, same deal the pressure has that circlip trapped as well.
Need the engine and flywheel on it OR some kind of fixture.
I think I'd have to bolt the PP to flywheel bolts to a bar and pull it a bit.
What an assclown PO on this...they took the clutch bolts out through the starter and clutch arm holes. (IMG:style_emoticons/default/dry.gif)
Mark Henry   Questions for a 3.0, #1 is adapting to a 901   Dec 27 2009, 09:20 PM
sww914   KEP has a starter ring gear and hardware that you ...   Dec 27 2009, 09:25 PM
pete-stevers   I would/did go for an early 3.0 with cis, it has T...   Dec 27 2009, 09:56 PM
jt914-6   When I first used my 3.0 I had my 901 modified to ...   Dec 27 2009, 10:15 PM
Mark Henry   When I first used my 3.0 I had my 901 modified to...   Jan 20 2010, 01:16 PM
J P Stein   Still debating to build a 2.0 or 2.4 or 2.7 or sa...   Dec 27 2009, 10:23 PM
Mark Henry   Number 3 and 4 are the ones that I'm debating ...   Dec 28 2009, 12:13 AM
rfuerst911sc   My 2 cents ( it's all I have left after this G...   Dec 28 2009, 06:08 AM
SirAndy   KEP Stage II, Starter Ringgear, Pressure Plate, 6-...   Dec 28 2009, 11:35 AM
J P Stein   I'll accept that the Stage II set-up works fin...   Dec 28 2009, 12:43 PM
Mark Henry   What is the $damage on that set up?   Dec 28 2009, 03:55 PM
SirAndy   What is the $damage on that set up? I don...   Dec 28 2009, 04:05 PM
rfuerst911sc   What is the $damage on that set up? Here...   Dec 28 2009, 05:54 PM
jt914-6   Here's a copy of my invoice from Patrick Motor...   Dec 28 2009, 06:59 PM
rfuerst911sc   Here's a copy of my invoice from Patrick Moto...   Dec 29 2009, 06:16 PM
9146986   Get #3 or #4 with a gaurantee, and the package fro...   Dec 29 2009, 08:46 PM
Dr Evil   Did you factor in that anything over 2.7 will need...   Dec 29 2009, 09:47 PM
Mark Henry   Here's my thinking on a 3.0 :idea: I have a ...   Dec 30 2009, 07:39 AM
9146986   You can put a 24 row Mocal oil cooler in the right...   Dec 30 2009, 08:20 AM
Dr Evil   For a CIS engine you can get away with no cooling ...   Dec 30 2009, 10:42 AM
Mark Henry   For a CIS engine you can get away with no cooling...   Dec 30 2009, 12:19 PM
Dr Evil   I agree with your logic. If the 3 CIS doesnt pass ...   Dec 30 2009, 12:39 PM
Mark Henry   JP you're such a buzz kill :stooges: Man.......   Dec 30 2009, 05:20 PM
rfuerst911sc   JP you're such a buzz kill :stooges: Man......   Dec 30 2009, 05:51 PM
J P Stein   JP you're such a buzz kill :stooges: It...   Dec 30 2009, 06:08 PM
J P Stein   A cool running engine is a long running engine. Th...   Dec 30 2009, 04:14 PM
Travis Neff   You can always do the cooler under the rear trunk.   Dec 30 2009, 05:50 PM
Mark Henry   Damn...just got offered another engine :blink: 7...   Dec 31 2009, 12:37 AM
rfuerst911sc   As a point of reference I purchased a 1978 3.0 wit...   Dec 31 2009, 05:50 AM
Mark Henry   Wish I could find a sub 100K mile engine for ...   Dec 31 2009, 07:56 AM
rfuerst911sc   Wish I could find a sub 100K mile engine for ...   Dec 31 2009, 08:51 AM
Mark Henry   Wish I could find a sub 100K mile engine for ...   Dec 31 2009, 09:48 AM
J P Stein   To me it's a core, but he didn't like t...   Dec 31 2009, 10:11 AM
brp986s   I just sold a set of core alusils to EBS. They pr...   Dec 31 2009, 10:01 AM
J P Stein   I just sold a set of core alusils to EBS. They p...   Dec 31 2009, 10:56 AM
sixaddict   My experince is 3. litre (or 2.7 ) on track needs ...   Dec 31 2009, 10:26 AM
Mark Henry   My experince is 3. litre (or 2.7 ) on track needs...   Dec 31 2009, 12:04 PM
rfuerst911sc   No affiliation but just came across this on Pelica...   Dec 31 2009, 01:49 PM
J P Stein   Well, there ya go. Tack on a rebuild kit.....bout ...   Dec 31 2009, 02:23 PM
Mark Henry   Well, there ya go. Tack on a rebuild kit.....bout...   Dec 31 2009, 09:41 PM
Justinp71   I bought a '81 complete core 3.0 with a good b...   Dec 31 2009, 08:31 PM
Mark Henry   Thanks for the link but I did see it same time as ...   Jan 1 2010, 09:51 AM
Justinp71   Thanks for the link but I did see it same time as...   Jan 2 2010, 12:08 PM
Mark Henry   [quote name='Mark Henry' post='1257016' date='Jan...   Jan 2 2010, 02:01 PM
J P Stein   I don't know enough about the guts of the 3.0L...   Jan 1 2010, 10:40 AM
Mark Henry   Just the stockers, but it has a mint set of nickis...   Jan 1 2010, 11:12 AM
iamchappy   Listen to Henry.....   Jan 1 2010, 11:50 AM
Mark Henry   Listen to Henry..... Will do...damn list is gro...   Jan 1 2010, 01:45 PM
SirAndy   damn list is growing Schlippery Schlope ... :D   Jan 1 2010, 03:35 PM
iamchappy   damn list is growing Schlippery Schlope ... :D...   Jan 1 2010, 09:36 PM
brp986s   :driving: = July 2010 ... July 2011   Jan 1 2010, 04:04 PM
Mark Henry   :driving: = July 2010 ... July 2011 :chair: ...   Jan 1 2010, 04:48 PM
J P Stein   The stock 3.0L with headers & carbs will give ...   Jan 1 2010, 09:25 PM
Mark Henry   Can a mod talk to iamchappy about him posting porn...   Jan 2 2010, 02:22 PM
rfuerst911sc   One thing you should budget is to have the stock 3...   Jan 2 2010, 04:10 PM
Mark Henry   One thing you should budget is to have the stock ...   Jan 2 2010, 06:28 PM
J P Stein   [Dizzy comes with it, but if I have to spend ...   Jan 2 2010, 06:44 PM
Mark Henry   [Dizzy comes with it, but if I have to spend ...   Jan 2 2010, 07:01 PM
rfuerst911sc   One thing you should budget is to have the stock...   Jan 2 2010, 07:33 PM
iamchappy   Do something right, thats well within your budget....   Jan 2 2010, 07:58 PM
Mark Henry   Can't afford that dizzy, ya bastard, would be ...   Jan 2 2010, 08:43 PM
iamchappy   Can't afford that dizzy, ya bastard, would be...   Jan 2 2010, 09:35 PM
J P Stein   CIS is one convoluted mo fo and the SC exhaust was...   Jan 2 2010, 08:58 PM
Mark Henry   yakky yak....what ?? you guys want me to go back t...   Jan 2 2010, 10:08 PM
Mark Henry   If I did go the JE route 9.5cr or the mahle 9.7cr ...   Jan 2 2010, 10:36 PM
Justinp71   Just took my 3.0 914-6 out, man your gonna have a ...   Jan 2 2010, 11:30 PM
J P Stein   I ran pump gas with the 9.7:1 Shastas. As the man ...   Jan 3 2010, 07:36 AM
Mark Henry   Is this piece of shite any good? :idea: What...   Jan 3 2010, 12:36 PM
J P Stein   Not ehuff info for me......but that's a hell o...   Jan 3 2010, 06:35 PM
Mark Henry   mahle RSR   Jan 3 2010, 06:41 PM
Mark Henry   side http://forums.pelicanparts.com/uploads15/Pis...   Jan 3 2010, 06:43 PM
Mark Henry   Box http://forums.pelicanparts.com/uploads15/Pist...   Jan 3 2010, 06:44 PM
Mark Henry   :) http://forums.pelicanparts.com/uploads15/Pisto...   Jan 3 2010, 06:45 PM
J P Stein   No fair, I can see the draft angle at the pin boss...   Jan 3 2010, 08:08 PM
Mark Henry   Can't I shim it and get 9.5 cr?   Jan 3 2010, 08:11 PM
J P Stein   Sure, ya got 2mm of base gaskets. :D Actually, I...   Jan 3 2010, 08:20 PM
Mark Henry   Was told these are only suppose to be around 9.7 c...   Jan 3 2010, 08:27 PM
J P Stein   Was told these are only suppose to be around 9.7 ...   Jan 3 2010, 08:34 PM
Mark Henry   Ok ok..... I know it's killing you :D Say ...   Jan 3 2010, 08:51 PM
J P Stein   I assume he stuck you for +dollars for the pistons...   Jan 3 2010, 09:09 PM
Mark Henry   No cams, he never got that far into the project, I...   Jan 3 2010, 09:41 PM
Mark Henry   I have a clutch out of a 71 that I can have real c...   Jan 20 2010, 07:33 AM
Dr Evil   If I understand you correctly, just pull the flywh...   Jan 20 2010, 11:53 AM
SirAndy   If I understand you correctly, just pull the flyw...   Jan 20 2010, 12:02 PM
Mark Henry   Nope, haven't had a fall down drunk since you ...   Jan 20 2010, 12:06 PM
Dr Evil   Yup, thats what I want. As for your pressure plate...   Jan 20 2010, 12:30 PM
Mark Henry   It is a 911 71 (I think) PP and was told by the lo...   Jan 20 2010, 12:36 PM
SLITS   As a temporary fix, just remove the circlip & ...   Jan 20 2010, 12:38 PM
Dr Evil   I am not sure if it will work for a 3.0 or not as ...   Jan 20 2010, 12:39 PM
Mark Henry   I can't see a circlip and the pivot bolt trick...   Jan 20 2010, 12:55 PM
sixnotfour   poke a screw driver down to the throw out bearing ...   Jan 20 2010, 01:41 PM
SLITS   poke a screw driver down to the throw out bearing...   Jan 20 2010, 05:46 PM
Mark Henry   I know how it comes out normally, I did remove the...   Jan 20 2010, 10:42 PM
SLITS   Need the engine and flywheel on it OR some kind ...   Jan 21 2010, 10:12 AM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 09:49 AM
