> cool engine
bill pierce
post Jan 22 2010, 05:46 PM
I'm thinking this would make an awesome engine for the 914
(IMG:http://i218.photobucket.com/albums/cc164/billpierces/engine2.jpg)
* 75° odd fire V8
* 2.8 LITER, 170 cu. in. displacement (3.0 liter optional)
* 84mm Bore X 63mm Stroke (67 stroke optional)
* 4 cams, 32 valves via internal silent chain
* 530mm wide x 485mm long x 530mm high
* 400HP @ 10,000 rpm with stock street cams (higher spec. is available)
* 245 ft-lbs torque @ 7500 rpm
* 200 lbs engine weight
* Billet nitrided steel 180° crank
* 4340 H-beam con-rods with ARP bolts
* Billet 6061-T6 aluminum crankcase
* Dry sump 0il system with 4 stage pump
* 7.25" or 5.5" Twin disc clutch
* DTA S80 full sequential ECU
* Unique cylinder offset and cam drive arrangement yields a compact design- Patent No. 7,168,405
http://www.h1v8.com/page/page/1562068.htm
aircooledtechguy
post Jan 22 2010, 05:54 PM
The Aircooledtech Guy
all this for under $28K. . . One nice sounding motor for sure!!
- Lo-Fi Version Time is now: 27th December 2024 - 01:43 PM
