tomkirkcis |
Newbie ![]() Group: Members Posts: 49 Joined: 19-October 06 From: massachusetts Member No.: 7,064 ![]() |
.I have been running searches for a couple of hours but can't find any info on fitment of 7r fuchs on a 914.
I have a narrow body 1970 factory 914-6 that has a hot 3.2SS motor and a close ratio LSD box Dr Evil built for me. It currently has 205/50 on 6 x 15 fuchs. Not enough tire . I have some AA metal flairs I got in a group buy a couple of years ago that I inteneded to install. I have four 9 x 16 fuchs that I was going to install all around . Certainly would take care things I am having second thoughts about installing flairs. It is just so much fun having a stock looking 914 with a big motor. I have access to a set of 4 7r Fuchs with 225/50 Brigestones. These are the Fuchs with the large backspacing Is anyone have 7Rs fitted to a narrow body? What tires can you fit? What spacers? Thanks Tom |
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,569 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Tom,
This is a picture of sixnotfour car wit 245-45-16 SO-s’s on 951 8’s roll the lip and pull a little. You still keep the stock body. That is what I have and am doing, as 400 ft lb with a LSD on a 930 should keep the rubber from spinning too much. Bob ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Tom, This is a picture of sixnotfour car wit 245-45-16 SO-s’s on 951 8’s roll the lip and pull a little. You still keep the stock body. That is what I have and am doing, as 400 ft lb with a LSD on a 930 should keep the rubber from spinning too much. Bob ![]() wow you have some good negative camber going there! |
Lo-Fi Version | Time is now: 28th June 2024 - 05:38 PM |
