jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
I have a great daily driver. 1.8 L motor with L-jet injection, and it jerks like a son of a %^$%. It has all new vacume lines, none of wich are leaking (idles smooth at 900rpm) i have blocked off the deceleration valve. It was not letting the idle come back down fast enough for my taste. New jugs rings pistons etc. It has new plugs and wires. a new resistor pack and a newer duel relay. new alternator and new voltage regulator. Valves adjusted .006/ .008 perfectly with new valve cover gaskets. It has a new fuel pump and fuel filter, and many new wiring harness. Injectors were all cleaned and new screens put in. It runs up to 5K with no problems and runs strong to about 110mph on a flat. (IMG:style_emoticons/default/driving.gif)
Whe i accelerate easy it starts to jerk the whole way. If i try to run in 2nd or 3rd it jerks the whole time even at constant speed. sometimes i will seesaw the clutch just so i dont look to embarrising. What is the list of things to check (i want to check everything) but i feel like i checked it all and then rechecked it (IMG:style_emoticons/default/confused24.gif) one other problem probably related, i cant keep constant power to the fuel pump through the relay, it chokes off sometimes and dosnt want to come back (PITA) so i jumped the fuel pump lead to the + coil for now. (dont be mad) (IMG:style_emoticons/default/rolleyes.gif) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,470 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
You have got crap compression on the cylinder at 65% leak. You can drive it on 3, as Rich says. if the valve seat is failing, it will fail faster if that part of the head gets hot, which it will if the cylinder is firing. If the seat falls into the motor, it will get unpleasant rather quick, and it would be best to avoid that.
I am free tomorrow (saturday) morning. I can follow you down to Fells with tools, and chase you back home. You can put the car in my garage for a short period of time - not longer then it takes to close on your house. But you can store it here short term. If this is somethign that you want to do, call me tomorrow earlyish and I will swing over and get you. Let me know. Zach |
jsayre914 |
You have got crap compression on the cylinder at 65% leak. You can drive it on 3, as Rich says. if the valve seat is failing, it will fail faster if that part of the head gets hot, which it will if the cylinder is firing. If the seat falls into the motor, it will get unpleasant rather quick, and it would be best to avoid that. I am free tomorrow (saturday) morning. I can follow you down to Fells with tools, and chase you back home. You can put the car in my garage for a short period of time - not longer then it takes to close on your house. But you can store it here short term. If this is somethign that you want to do, call me tomorrow earlyish and I will swing over and get you. Let me know. Zach Zach is a very generous guy. (IMG:style_emoticons/default/beerchug.gif) I did not have time to get it home last night, I will be attempting tonight about 8pm. I will pull the injector lead and run nice and slow, and stop to check the valve a few times along the way. I will let you guys know ... hell if i can drive it 60 miles with no clutch (IMG:style_emoticons/default/chair.gif) this should be a cake walk (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 07:26 AM |
