23mm Master Cylinder, ATE # W0133-161214 |
Eddie914 |
Jan 24 2010, 03:51 PM
Unregistered |
I'm installing 4 piston Wilwood calipers and believe that a larger master cylinder is recommended.
Is this the correct part? ATE # W0133-161214 76 1976 Mercedes 450SL Brake Master Cylinder - Brake - ATE - PartsGeek (4th one down) Thanks Eddie |
Eddie914 |
Jan 25 2010, 04:28 AM
Unregistered |
Ron,
Where did you get the part. Does the actuating rod need to be replaced? Are adapters needed for the brake line fittings? Thanks Eddie |
Lo-Fi Version | Time is now: 27th December 2024 - 04:43 PM |
