Narrow body fuch 7R fitment, anyone running fuch 7R wheels? |
tomkirkcis |
Jan 23 2010, 10:38 AM
Newbie Group: Members Posts: 49 Joined: 19-October 06 From: massachusetts Member No.: 7,064 |
.I have been running searches for a couple of hours but can't find any info on fitment of 7r fuchs on a 914.
I have a narrow body 1970 factory 914-6 that has a hot 3.2SS motor and a close ratio LSD box Dr Evil built for me. It currently has 205/50 on 6 x 15 fuchs. Not enough tire . I have some AA metal flairs I got in a group buy a couple of years ago that I inteneded to install. I have four 9 x 16 fuchs that I was going to install all around . Certainly would take care things I am having second thoughts about installing flairs. It is just so much fun having a stock looking 914 with a big motor. I have access to a set of 4 7r Fuchs with 225/50 Brigestones. These are the Fuchs with the large backspacing Is anyone have 7Rs fitted to a narrow body? What tires can you fit? What spacers? Thanks Tom |
messix |
Jan 25 2010, 01:22 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
don't roll, use a thin cut off wheel on a die grinder and cut the lip but leave about 1/4 inch. it's to easy to cause some damage that you will have to repair.
and to get some streach use a shot bag or sand bag agianst the fender and a 2x4 on that and then use a sissor jack against the inner fender well. this should keep from distorting the outer fender while getting about an inch pushed out. |
mskala |
Jan 25 2010, 12:06 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Tom,
There is no one answer for widest rubber in the stock fenders, there are too many variables. Tire brand, camber, spring rate, ride height, factory workers' alcohol content that day, etc. Measuring and test fitting is the only way. Too bad I don't have my boxster wheels with auto-x tires any more or I could lend you. Mark S. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:12 AM |
