Original Light Ivory Color & Mix?, ...L80E, 11, 1110, etc......????? |
Tom_T |
Nov 17 2009, 09:54 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Okay, so I want to take my early-73 914-2.0 (marketed in USA as a "914S" then) back to the original OE Light Ivory color, which I can still see under the floor mats, etc. (IMG:style_emoticons/default/idea.gif)
The problem is, I'm seeing quite a range of this innocuous color on various 914s & 911s, ranging from a bright white to a more mellow off-white befitting the "light ivory" name, and I'm seeing color chart sample chips in that same range! (IMG:style_emoticons/default/blink.gif) Then to compound that, the 73MY documents which I've found online call the color L80E in some places & 1110 in others, while my COA calls it only 11. Of course they also call my #31 Beige upholstery "black" - contrary to those documents' interior codes & even their own other COAs where black is #11! (IMG:style_emoticons/default/headbang.gif) So does anybody have the proper L80E/1110/11 "Light Ivory" paint tint/color mix formula for a 1973 MY 914?? (IMG:style_emoticons/default/confused24.gif) Here are a few examples from my research to illustrate my dilemma.... L80e chip from Wolfsburg West on 73 VW Conertible Bug: 72 914 Dealer Color Samples: 71 PPG VW Paint Color Chart with L80E: 74 914 Dealer Color Samples: 72 Porsche Dealer Color Codes - Paint & Interior: ...continued.... |
davep |
Jan 25 2010, 08:47 PM
914 Historian Group: Benefactors Posts: 5,213 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes, PCNA has fixated on a marketing paint code rather than what was actually stamped on the car, and this tends to lead to a lot of confusion. They are not wrong, just confusing.
The paint formulations are subject to change over time. The paint used on the car at the factory is no longer available, so I think the best you can do is find a painter you trust, and use the paint that he wants to use (and is experienced with so that a desirable result is produced); forcing a painter to use a paint he is not familiar with is asking for trouble. Then work with the paint supplier to come up with the formula for VW L80E; do a test panel if needed; wet and cured will look different as will a 37 year old sample. |
Lo-Fi Version | Time is now: 25th November 2024 - 11:34 AM |
