URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,328 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I bought this car in February 2007 from our former member "Rouser", Roy Galen. It came with another '73 2.0 parts car which was badly rusted and a load of parts. It had a bad wheel bearing which I replaced (both) and I changed the rear springs to #180. It has factory sway bars front and rear so it handles pretty well. I haven't done much else to it beside add gas and oil. The car was not originally red but it was a pretty through job with the trunks/jamb/etc painted as well.
It came with a few rust problems: rear trunk, trunk lid, driver/pass floors, jack plate, and other minor paint bubbles. It also has a IMSA f/g nose on it, but Roy had already collected a nice bumper/cap/valance. The best thing about it is it has been converted to five lug Fuchs and they are real not fakes. The hell hole is not bad at all really. It also has A/C and dual 44 Webers on the otherwise stock 2.0. I've now cleaned out the garage to make room and today I moved it in with my race car (also a '73). The plan of attack will be: -replace rear trunk floor -replace driver's and pass. floors -remove the front end and replace with stock -repair all the rusted areas -remove the rear reflector -paint -drive as if stolen I've built a race car, so lets see if I can work on a street car. I will do my best to keep my sawzall away from it. (IMG:style_emoticons/default/biggrin.gif) It looks pretty good when wet and at the right angle and distance... BTW- that targa bar is raddle can painted not vinyl and the lower chrome trim is 1/4 "chrome" pin striping tape. Attached image(s) ![]() ![]() |
URY914 |
Tonight I re-installed the shift console and refilled it with gear lube.
I rolled it out of the garage and started it up. It fired off on the second crank. Ahhhhh, the sweet sound of a running engine. (IMG:style_emoticons/default/beer.gif) Tomorrow night it hits the road. (IMG:style_emoticons/default/biggrin.gif) |
Rouser |
Anti-Post Whore ![]() ![]() ![]() Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 ![]() ![]() |
Tonight I re-installed the shift console and refilled it with gear lube. I rolled it out of the garage and started it up. It fired off on the second crank. Ahhhhh, the sweet sound of a running engine. (IMG:style_emoticons/default/beer.gif) Tomorrow night it hits the road. (IMG:style_emoticons/default/biggrin.gif) Man, you have accomplished SO much on that 914 I can hardly recognize it; I would've NEVER been able to do as much as you have. That front end is beautiful ... glad you finally scraped off that air dam(mit). I got that bumper (lights and all) from Campbell out in CA years ago with the intention of doing just that, but like so many projects, other stuff always comes up. The mirror issue? Yep, saw THAT setup myself (from previous owner) and just made it work until I could deal with it later (insert years here). Riveted floor panels/patchwork? Yep, my best fix since you didn't notice a MIG/TIG/candle-wax-powered welding ANYTHING in my garage on your last visit. Bondo Sally? That was all the PO before me, knowing I would expect a few surprises once I got into her bodywork (again, insert years here). But I do miss the ol' girl ... we had a LOT of fun pissin' off quite a few Toyohondabishis to-and-from work. |
Lo-Fi Version | Time is now: 28th June 2024 - 12:45 PM |
