Seat adjuster handle blow out! 1/4" steel Powdercoate, These will NEVER break $14.99 |
Mikey914 |
Jan 22 2010, 02:56 AM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The jack straps are taking a little longer so I wanted to add in one other item that could be combined to save money on shipping.
These are machined from 1/4" steel and powdercoated black. Installation is pretty simple. To remove the old handle you have to drill out or shear off the heads fo the small brass rivets that hold on whats left of the old handle. Then drill the same holes with a 1/4" drill bit. The new handles have the same spacing, so that yuo can then mount using the machine screws. I'm will be running a special on these and they can be combined with the other items coming online. Sign up here if you want one. I'll be forwarding paymant info tomorrow. Thanks, Mark Attached thumbnail(s) |
mikea100 |
Jan 29 2010, 12:11 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
I'll take 2, if you have any left.
Lo-Fi Version | Time is now: 28th December 2024 - 01:30 AM |
