McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation. This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it. There is no other setup built specifically for our motors. Quick easy installation with no headaches. Complete package price is $175 and includes the trigger wheel, the sensor w/ connector (pigtail or uncrimped), and the mounting bracket. You won't need to go searching for anything else. (IMG:http://www.914world.com/bbs2/uploads/post-419-1244942673.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1245008370.jpg) |
McMark |
The adjustment in MegaTune is super easy and I can help with that, but if you absolutely need the missing tooth in a certain place, I can accommodate that as well.
Lo-Fi Version | Time is now: 20th April 2025 - 12:15 AM |
