Runner |
Newbie ![]() Group: Members Posts: 4 Joined: 6-January 10 From: Cottonwood, CA Member No.: 11,206 Region Association: None ![]() |
Fellow track drivers:
Need some ideas on general suspension components for a V8 track car that you have had good success with. Anyone running a V8 car on road courses that can give me some general set-up ideas would be great. Thanks, Mark |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
dont forget the suspension bushings. if they werent already dead before teh v8, they will be soon. fat torsion bars with stock old bushings will get a notch rubbed into them
stewteral |
Old Member ![]() ![]() Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California ![]() |
dont forget the suspension bushings. if they werent already dead before teh v8, they will be soon. fat torsion bars with stock old bushings will get a notch rubbed into them Sean: Ah the BUSHINGS! Great point! I couldn't imagine trying to run a V8 car with rubber bushings! The rear suspension would be dancing all over the place! After doing the whole nasty Burn-the-rubber-out-of-the-swing-arms thing, I'm installed in poly-graphite all around. They tend to squeak a bit, but squirting lube via the ZERK fitting I added helps for a while. With the Exhaust open at the track, I NEVER here them! (IMG:style_emoticons/default/smile.gif) On my home-made tubular front swaybar, I used bronze bushings with seem to work well. In mounting the Rear bar, I used a 1" OD tube and could buy poly-bushed swaybar bracket WITH ZERK fittings from Summit Racing for ONLY $16...what a bargain. Best, Terry |
Lo-Fi Version | Time is now: 25th June 2024 - 10:21 PM |
