TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I have got some Welt bushings and at first glance they looked the same and I didn't think much until I saw part numbers.
MO2557 MO2558 Which ones are for the front of the front A-arms, and which is for the rear of the front A-arms? Also I did this order over the phone and I asked for street bushings, can anyone confirm by my part numbers above?? |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
i just had this exact problem! you order from PP? (they just put four in a sack)
anyway. one set is slightly larger outside diameter (.00X difference IIRC) i measured the housings, and one is .00X bigger than the other. i believe xxxx7's were on the front. ill check for you tommorow |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:15 PM |
