mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,326 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
2 questions-
When I flare my car, I'm going from a 2.0 alloy 5.5x15 with 205x60x15 tires. I would like to keep the tire diameter the same on a 7x15 wheel and 225 tire. Would I use 50, 55 or 60 series tires? I think a 7 inch wheel and 225 tire might still have too much space between the tire and inside of the flare. Is there a spacer made that will fit a 4 lug wheel? I have read that the 4 lug hub takes a special lip on the wheel. Thanks, Mark |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I'd strongly recommend switching to the five lug pattern, you'll be happy you did and your wheel choices are much wider.
Plus, 5 lug wheels just look right with the flaired fenders! |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
I'd strongly recommend switching to the five lug pattern, you'll be happy you did and your wheel choices are much wider. pun intended! (IMG:style_emoticons/default/biggrin.gif) acording to this site the 225x55x15 is exactly the same dia. (24.7") http://www.miata.net/garage/tirecalc.html |
Lo-Fi Version | Time is now: 20th June 2024 - 09:02 AM |
