carbs |
carbs |
RonnieJ |
Feb 27 2004, 11:55 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
What does my fellow 914 teeners think. I have a 1.7 with 40 webers. I get a slight pop and hesitation while accelerating. Is it the carbs or timing? I'm a newbie and need some help.
Ron |
914ghost |
Feb 27 2004, 02:42 PM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
Check accelerator pumps too.
If theres a slight or BAD lag right when you hit the throttle but a little touchy throttle 'feathering' gets you going then its usually accel pumps. Clogged or Mal-adjusted. Look in the carb (yeah airlceaner off)...be careful of the backfire though (or do it while the car is OFF- but not too many times or you'll flood it.) and see if fuel is squirting nice and steady for a second just as the throttle is activated. Good? Get a weber tech book and follow their advice.. If you have carbs on a car you expect to drive, its worth a thousand bucks to have a book- but it only costs like $15. Bob O my prediction: next reply says- go back to fool injection. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 11:50 AM |
