Type 1 build ?'s, Mark, Jake et all |
scotty b |
Feb 14 2010, 02:58 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I'm putting together an 1835 I had in my Baja years ago, before I knew what I was doing. I originally used Weber progressive which in hindsight I realize was the main reason I melted number 3.......twice (IMG:style_emoticons/default/dry.gif) The case is a VW f.i. case, lign bored by one of the best around here, heads WERE stock, That's where my ? comes in. I know when I used to be into VW's hardcore the 041's were the things for a mild streeter. Now with the advacements of the last 15 years what is recommended ? 044's? How about carbs ? 40 IDF's ?
I'm well aware of the issues with 92's but I already have 2 1/2 sets of near new ones so that is what I will be using. (IMG:style_emoticons/default/dry.gif) What I have for it : c.w. 69 mm crank 92mm Mahles Engle 120 cam balanced stock rods ( unless someone has something nicer for a good price (IMG:style_emoticons/default/biggrin.gif) ) full flow high flow pump sump extractor from a Euro high tuck system, will probably run a stinger on it Heads ??? Carbs ????? other suggestions ?????? |
RJMII |
Feb 14 2010, 03:12 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
(IMG:style_emoticons/default/cool.gif)--><div class='quotetop'>QUOTE(scotty b @ Feb 14 2010, 01:58 PM) </div><div class='quotemain'><!--quotec-->
I'm putting together an 1835 I had in my Baja years ago, before I knew what I was doing. I originally used Weber progressive which in hindsight I realize was the main reason I melted number 3.......twice (IMG:style_emoticons/default/dry.gif) The case is a VW f.i. case, lign bored by one of the best around here, heads WERE stock, That's where my ? comes in. I know when I used to be into VW's hardcore the 041's were the things for a mild streeter. Now with the advacements of the last 15 years what is recommended ? 044's? How about carbs ? 40 IDF's ? [/quote] I'll sell you an "n". =o) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) I'm interested in your build. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 01:45 PM |
