ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
Somewhere earlier I saw a comment that Jake had recommended using 911 Valve Adjusters in the Type-4 engine... Or maybe he had recommended against it. I can't remember.
Anybody out there have experience in this? My adjusters and adjuster nuts were pretty gnarled when I got my car a few years ago. Now with bi-monthly adjustments, I'm looking to replace them. Will the 911 adjusters fit the existing rocker arms? Do I need the same nuts? If I go ahead with this, should my properly adjusted valves run quieter? And is there any advantage to replacing the springs? As a result of some moderate leaky valve guides, my plans are to have the heads re-built this winter. Should I wait until the heads are rebuilt, or is there any reason I shouldn't go ahead with the adjusters, nuts and springs right now? Any thoughts? My thanks. Eric Read |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
I here the CB ones are ok. It's the empi and bugpack stuff you need to stay away from. Don't know first hand though.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I here the CB ones are ok. It's the empi and bugpack stuff you need to stay away from. Don't know first hand though. The Porsche ones are good. First class. The CB ones are "OK". The rest are cr*p, more or less. You care about your work? Use the Porsche ones. You just wanna brag (I can use that word, right? I mean he doesn't have a patent on it or anything, does he?) you have "swivel feet" and don't give a rat's arse about the quality of the work? Use the CB ones. Personally, for a stocker, I don't see any reason to use anything than good quality stock adjuster screws and nuts. Mind you, there are some el cheapo screws out there that aren't worth the price of the postage to get 'em to you. The Cap'n |
Lo-Fi Version | Time is now: 30th June 2024 - 06:16 PM |
