My chassis twisted hardcore |
turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
turnaround89 |
Feb 17 2010, 11:25 PM
the weirdest part is that the door hangs low at the back...i don't think the car is unsafe to drive, its just the doors will not line up. The chassis is way stronger than it used to be. I took some measurements, and the car has shrunk...the gap from the windshield frame to the targa bar is the only severely off measurement, everything else seems right
davesprinkle |
Feb 17 2010, 11:41 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
the weirdest part is that the door hangs low at the back...i don't think the car is unsafe to drive, its just the doors will not line up. The chassis is way stronger than it used to be. I took some measurements, and the car has shrunk...the gap from the windshield frame to the targa bar is the only severely off measurement, everything else seems right That's right, you've curled up the longs into a curve. The door sits low, the door opening is the wrong shape, the targa bar is too close to the windshield header, your wheel alignment is screwed. It might be stronger, but it's definitely not better. I know this sucks to hear, but you need to try to undo this. You should cut a series of slots through the added sheet metal to relieve the stresses that you've locked into the car. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:49 PM |
