> Upgrade your headlight relay to electronic, How to wire up the new relay
Mike Bellis
post Feb 16 2010, 10:42 PM
Resident Electrician
The factory highbeam relay is a mechanical toggle relay. As they get old, they stop working correctly. It takes multiple pulls on the colum switch to engage the highbeams. Some may stop working completely.
Below you will see how to wire up an electronic relay. It's very easy to do. The very smart European builders have standardized their relay terminals. So many manufaturers relays will work. The picture below is a Saab relay. This relay can be found for $5-10 at junk yards. The 914 relay is about $50
You will need to jumper terminals 30 and 86 together with the 914 wire from terminal 30
Terminal 56a will go to the 914 Yellow headlamp wire
Terminal 56b will go to the 914 White headlamp wire
Terminal S will go to the 914 wire from Terminal S
The final wire will be a new Ground wire you will add to terminal 31
That's it! You will now have an electronic highbeam relay. Now you have to figure out how to mount it.
Krank
post Feb 18 2010, 05:19 PM
If this circut is just used for the dimmer circut then I believe you could just use a brand new switching relay to achieve the same results. They run about 10.00 to 15.00 I don't have the 914 schematics so I can't tell you which wire goes where but the relay used in the above example (it is a mechanical one also btw) utilizes one power source and switches it from one output to the other. You can also then use a brand new base connector to make everything look neat and tidy. If someone would send me the schematics of the lighting system I could make a lighting schematic with the new relays.
HELLA relays and bases
http://www.hella.co.nz/?m=search&f=rel...6&B1=SEARCH
(bottom two relays)
Note: use the 40amp circut for the hi beam (pin 87)
A note on using diode relays with sensitive electronic equipment like fancy disc players
http://www.hella.co.nz/?t=9&pcid=251
They do list a solid state relay but not a switching one
You can even use a delay relay to have a fancy courtesy lighting system so your lights stay on for a short interval after you turn your car/lights off.
I used two switching relays to replace the power window system in my '68 Lincoln Continental. The polarity needs to be reversed to operate a DC motor in the other direction. I also used a switching relay to supply power to my road lights on my pick-up only when my high beams are on so that I can dim my high beams and turn off my road lights with one click rather than fumbling around for another switch as a car approaches. Relays are fun! (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post Feb 18 2010, 07:35 PM
QUOTE(Krank @ Feb 18 2010, 03:19 PM) *
(bottom two relays)
Those relays are standard SPDT (Single Pole Dual Throw) relays. They will not work for the dimmer. the 914 and most other cars send out a ground pulse every time you pull the lever. It does not latch on or off. You could build a latching relay setup with 2 or 3 SPDT relays and use the ground pulse to trigger it. Way more difficult.
The Saab relay and the like use an electronic circuit to hold the latch on or off. On the Saab relay terminal 86 is the switched power from the key and terminal 30 is the power from the lighting circuit. Since the 914 lighting power is controlled by the key, these two terminals jump together. Terminal 31 is a ground for the electronic circuit.
On the 914 relay terminal 30 is the light power AND the positive for the coil. The S terminal is the momentary ground for the coil. When the coil is grounded, the relay pulls in and toggles a cam inside the relay. when the relay de-energizes the cam drops on a mechanical tab that directs the cam right or left. It is designed to toggle right then left then right again every time you pull the lever. Over time the centering spring on the cam will develope a memory to the right or left. this causes the cam not to toggle to the other side of the tab. Hence the cam will always land on the high OR low side contact and never switch over.
I think the bottom line is this. You can make it work with multiple SPDT relays and build a latch circuit. A single replacement relay is a cleaner install and more reliable.
kg6dxn   Upgrade your headlight relay to electronic   Feb 16 2010, 10:42 PM
SirAndy   :thumbsup: I've been thinking about doing that...   Feb 16 2010, 10:50 PM
pbanders   Very cool, thanks! BTW, most OEM headlight rel...   Feb 17 2010, 12:26 PM
kg6dxn   Very cool, thanks! BTW, most OEM headlight re...   Feb 17 2010, 11:04 PM
76-914   Good info. Could this be added to our classic thre...   Feb 17 2010, 11:28 PM
kg6dxn   Good info. Could this be added to our classic thr...   Feb 17 2010, 11:30 PM
SirAndy   I'll be able to look it up later when I need ...   Feb 18 2010, 06:16 PM
76-914   I'll be able to look it up later when I need...   Feb 19 2010, 09:18 AM
stephenaki   I just may have to do this as I think meine relay ...   Feb 18 2010, 08:31 AM
jim_hoyland   Is the original high / low relay square ? Can...   Feb 18 2010, 01:00 PM
Krank   If this circut is just used for the dimmer circut ...   Feb 18 2010, 05:19 PM
kg6dxn   If this circut is just used for the dimmer circut...   Feb 18 2010, 07:35 PM
tracks914   Or you could just drive it on sunny days!...   Feb 18 2010, 08:36 PM
jim_hoyland   Where is the replacement unit mounted ?   Feb 19 2010, 10:14 AM
kg6dxn   Where is the replacement unit mounted ? You wil...   Feb 19 2010, 05:41 PM
9146986   This is good stuff Mike!   Feb 19 2010, 05:30 PM
siverson   So this Saab relay is just used to replace the swi...   Aug 4 2013, 10:56 AM
kg6dxn   So this Saab relay is just used to replace the sw...   Aug 4 2013, 11:56 AM
Cap'n Krusty   Nice. FYI, the "builders" aren't re...   Aug 4 2013, 04:51 PM
siverson   Thanks. I got this working yesterday. Saab relay f...   Aug 5 2013, 04:56 PM
siverson   914   Aug 5 2013, 04:57 PM
porsche913b_sp   great thread and so convenant since I am tracking ...   Sep 21 2015, 10:48 PM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 1st January 2025 - 01:04 AM
