neilca |
Member ![]() ![]() Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 ![]() |
I am setting up an EP 914-6 for SCCA regionals. I have 22mm front torsion bars and 350# springs in the rear. How low can I set the ride height? I have found the bolts that hold in the front sub frame to be the lowest point of the car and I can adjust the bars till it hits the ground. The rear I use the jack points on the back corners of the tub. I can lower these down to 2" off the ground. I have a set of the 23mm front bars also and can get heavier rear springs if needed. Any suggestions? I am runing cantilevered slicks from Goodyear. I will be running tracks like Road Atlanta, Barber, Roebling and CMP. How low can I go? Thanks, neilca. |
neilca |
I have set the ride height. I decided the rules dictate how low to set the car. I put a rim on the LF corner with no tire, simulating a flat tire condition. Lowered the car to the ground and set the ride height such that the lowest point was 1/2" off the ground. Put the regular tire back on and measured 2 3/4" from the jack nub ( this is the boss on the bottom of the tub in the four corners). I then set the rear to 3 3/4" in the rear to give the car some wedge for down force.
Now on to corner balancing, see post on the subject. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:29 AM |
