My chassis twisted hardcore |
turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
Katmanken |
Feb 19 2010, 12:35 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Wouldn't do it.
They are designed for adhering non-structural body parts. They require really clean non-rusty metals, our are cars are old and rusty, and the rust never sleeps. I can guarantee that if a rust bubble forms under a glue joint that the pressure from the growing rust cell is so large that it will delaminate the joint. Might take time, but a structural use would fail just when you don't want it- ie under a cornering load. There are stuctual aircraft adhesives, but they work on clean aluminum. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:56 PM |
