| McMark |
Feb 19 2010, 02:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
![]() I'm now offering this speedo drive gear modification to help seal one of the more persistent leaks on the 914 transmission. By adding a second, lower o-ring to this part it not only gains a second barrier again leaking, but also helps reduce the vibration that can wear the clearances and cause further leaking. This part sits inside the transmission tail cone and the angle drive screws into it, then the cable attaches to the angle drive. ![]() The new internal seal is noticeably smaller on the ID. This means more sealing pressure against the gear shaft, and therefore better sealing against oil leaks. ![]() Now available HERE from 914Rubber. This member (Thanks Eric!) had a significant leak at the speedometer, even while parked. After this modification was done... ZERO LEAKS! Read his story here. |
| SirAndy |
Feb 19 2010, 02:53 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,370 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Great idea! (IMG:style_emoticons/default/smilie_pokal.gif)
After years of abuse, the case often is slightly oval allowing for oil to seep by. A second o-ring should take care of that ... (IMG:style_emoticons/default/w00t.gif) Andy |
McMark Speedo Drive Gear Sealing Modification Feb 19 2010, 02:05 PM
9146986 VERY COOL!!! You get a gold star McMa... Feb 19 2010, 05:26 PM
whatabout1 PM sent Feb 19 2010, 05:54 PM
ConeDodger This looks cool. Mine doesn't leak that I know... Feb 19 2010, 07:11 PM
Sleepin Awesome! Feb 19 2010, 10:14 PM
McMark These are now available only as complete rebuilds,... Mar 9 2010, 11:26 PM
eyecolor Count me in
Tell me how to pay and where to send... Mar 16 2010, 07:16 AM
McMark PayPal: $65 to mark@originalcustoms.com
Core... Mar 16 2010, 11:46 AM
McMark Sleepin' posted his experience with the speedo... Mar 24 2010, 12:32 PM
jflash914
Sleepin' posted his experience with the speed... May 31 2010, 02:39 PM
BKLA When I removed my speedo drive for my track day ca... May 31 2010, 06:00 PM
McMark Jack, once the set screw is removed the speedo dri... May 31 2010, 09:22 PM
jflash914
Jack, once the set screw is removed the speedo dr... Jun 1 2010, 08:20 AM
john_g
Jack, once the set screw is removed the speedo dr... Feb 5 2013, 10:23 PM
Kevins911 Hi Mark, just wondering if you are still making th... Jun 25 2010, 12:41 PM
McMark Yes I am. I'm waiting on more seals from Pors... Jun 25 2010, 01:17 PM
Ericv1
Yes I am. I'm waiting on more seals from Por... Jul 1 2010, 07:21 AM
McMark Turn around time is one day. The only piece I nee... Nov 10 2010, 03:33 PM
SUNAB914 Hey I will order one as soon as I get settled in o... Dec 24 2010, 06:51 AM
McMark Gear seal kits are now available with the speedo d... Mar 29 2011, 04:04 PM
pktzygt Are the drive gear mod and the gear weal kits curr... Mar 21 2012, 03:56 PM
McMark Speedo gear mod can go out tomorrow.
Trigger whe... Mar 21 2012, 04:19 PM
euro911
Great mod ... you won't regret doing it Feb 6 2013, 01:54 AM
john_g
T... Feb 6 2013, 03:18 PM
McMark Thanks Mark! Didn't even think of using t... Feb 6 2013, 09:37 AM
john_g
Thanks Mark! Didn't even think of using ... Feb 6 2013, 03:35 PM
euro911 I'm good for something every now 'n then .... Feb 6 2013, 03:23 PM
McMark Yup. Available at my store. Feb 6 2013, 03:38 PM
john_g
I'm having gre... Feb 7 2013, 11:06 PM
HalfMoon Order sent!
Great lil fix, thanks!
David
B... Jan 2 2014, 12:51 PM
no1uno Just ordered speedo drive gear upgrade using webst... Feb 12 2013, 02:38 PM
maf914 Mark, I placed an order for your speedo drive gea... Jan 7 2014, 07:17 AM
914_3.0 Just what I need. Off to your store. Feb 10 2014, 10:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:16 AM |
