Upgrade your headlight relay to electronic, How to wire up the new relay |
Mike Bellis |
Feb 16 2010, 10:42 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The factory highbeam relay is a mechanical toggle relay. As they get old, they stop working correctly. It takes multiple pulls on the colum switch to engage the highbeams. Some may stop working completely.
Below you will see how to wire up an electronic relay. It's very easy to do. The very smart European builders have standardized their relay terminals. So many manufaturers relays will work. The picture below is a Saab relay. This relay can be found for $5-10 at junk yards. The 914 relay is about $50 You will need to jumper terminals 30 and 86 together with the 914 wire from terminal 30 Terminal 56a will go to the 914 Yellow headlamp wire Terminal 56b will go to the 914 White headlamp wire Terminal S will go to the 914 wire from Terminal S The final wire will be a new Ground wire you will add to terminal 31 That's it! You will now have an electronic highbeam relay. Now you have to figure out how to mount it. |
IronHillRestorations |
Feb 19 2010, 05:30 PM
I. I. R. C. Group: Members Posts: 6,793 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
This is good stuff Mike!
Lo-Fi Version | Time is now: 1st January 2025 - 12:15 AM |
