My chassis twisted hardcore |
turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
Eric_Shea |
Feb 20 2010, 11:44 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Also, that window frame doesn't really do "jack" for measurement purposes. I can bent one of those easily by hand. You'll get a bunch of various windshield frame measurements here that are probably 1/4" off. There "is" a standard top frame measurement BUT, get the proper jam measurements first and then worry about the frame.
Hit that link I sent you and get door frame measurements as Rick suggested. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:43 PM |
