Head studs, Type 1 on a Type 4? |
enikolayev |
Feb 20 2010, 02:13 PM
Member Group: Members Posts: 50 Joined: 18-November 07 From: Gulfport, MS Member No.: 8,349 Region Association: South East States |
Missing one head stud for my TIV. Can i use the Type 1 head studs? I have several used Type 1 cases lying around.
I'm guessing its not a good idea to just replace the one head stud since the Type 1 head studs are much thicker and could have a different expansion rate? What if i replaced them all? |
Katmanken |
Feb 21 2010, 12:20 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
(IMG:style_emoticons/default/barf.gif)
The head stud designs are critical. Randomly swapping out studs that kinda look alike but are different diameter, different length and possibly different material is a no-no. Kinda like trying different size bullets in a gun to see if they will work. The studs are carefully designed to apply a certain force on the head for the torque on the nut. The idea is to hold the head in place with enough torque so the head doesn't move away from the cylinder when the engine fires. Stud stretch is carefully designed in, and the expansion and contraction due to temperature plays a part in the design of the stud and the torque. Different diameter, different length or different material will make the odd stud behave unlike the others. |
ME733 |
Feb 21 2010, 02:37 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/barf.gif) The head stud designs are critical. Randomly swapping out studs that kinda look alike but are different diameter, different length and possibly different material is a no-no. Kinda like trying different size bullets in a gun to see if they will work. The studs are carefully designed to apply a certain force on the head for the torque on the nut. The idea is to hold the head in place with enough torque so the head doesn't move away from the cylinder when the engine fires. Stud stretch is carefully designed in, and the expansion and contraction due to temperature plays a part in the design of the stud and the torque. Different diameter, different length or different material will make the odd stud behave unlike the others. .....................You are correct- completely.......M.M. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:24 AM |
