turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
turnaround89 |
What makes the celette better than othe racks? Also, is there anything that will need to be removed from the car, bumpers, suspension, etc? Id like to take the car there as a rolling chassis that way its easier to get it on the trailor. the pictures show the car as just a shell, i was hoping i could leave the suspension on.
Lo-Fi Version | Time is now: 25th June 2024 - 09:55 PM |
