turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
turnaround89 |
What makes the celette better than othe racks? Also, is there anything that will need to be removed from the car, bumpers, suspension, etc? Id like to take the car there as a rolling chassis that way its easier to get it on the trailor. the pictures show the car as just a shell, i was hoping i could leave the suspension on.
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
What makes the celette better than othe racks? Also, is there anything that will need to be removed from the car, bumpers, suspension, etc? Id like to take the car there as a rolling chassis that way its easier to get it on the trailor. the pictures show the car as just a shell, i was hoping i could leave the suspension on. The Cellette is a fixture type bench. The one in the photos does not show the fixtures. They are using a lazer to check the car. It seems as though the Cellette rep was offering the shop the option of renting the proper fixtures. I'm kind of under the impression the shop in that link is selling their service as a Porsche repair shop and showing the Cellette bench but doesn't rent the fixtures when they do chassis work. Here is a link to Sir Andy's severly bent chassis. This was repaired on a Cellette with proper fixtures. I don't know what it cost him but this is how you fix a 914. Yes you will need to drop the suspension for the fixtures. http://www.914world.com/bbs2/index.php?sho...c=92489&st= |
Lo-Fi Version | Time is now: 25th June 2024 - 10:01 PM |
