My chassis twisted hardcore |
turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
turnaround89 |
Feb 22 2010, 12:18 AM
does the place doing the chassis alignment rent the fixtures or is that something i have to locate?
rick 918-S |
Feb 22 2010, 12:56 AM
Hey nice rack! -Celette Group: Members Posts: 20,826 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
does the place doing the chassis alignment rent the fixtures or is that something i have to locate? I'd just call this guy. I'm sure he can tell you which shop in your area can bench your car. Greg Fritz Sales and Technical Support 630-396-6100 ext 6170 Office 630-495-4078 Fax www.celette-na.com |
rick 918-S |
Feb 22 2010, 01:08 PM
does the place doing the chassis alignment rent the fixtures or is that something i have to locate? I'd just call this guy. I'm sure he can tell you which shop in your area can bench your car. Greg Fritz Sales and Technical Support 630-396-6100 ext 6170 Office 630-495-4078 Fax www.celette-na.com I had a conversation with a Cellette rep. He is emailing info about the fixture availability, location and cost. I can either get you hooked up with the local shop or if they are tired of the old Cellette collecting dust in the corner I may just purchase the thing. This will happen whether you ever fix your car or not. I have The raspberry car with a missing front clip and Sandy's I'm picking up in Cali in like two weeks. It took a hit to the front. Your inquiry just prompted me to do something I have been wanting to do for a long time anyway. |
SirAndy |
Feb 22 2010, 01:16 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Your inquiry just prompted me to do something I have been wanting to do for a long time anyway. If you do, don't forget to make a 'backup copy' of the fixtures ... (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 27th December 2024 - 11:04 PM |
