> My chassis twisted hardcore
turnaround89
post Feb 17 2010, 08:04 PM
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
IronHillRestorations
post Feb 26 2010, 12:40 PM
I. I. R. C.
Thanks Rick! I felt kinda stupid after my post, as I found your prior post with his contact info (IMG:style_emoticons/default/wacko.gif)
I spoke with Greg and it looks like the Celette fixtures will fit my bench!! (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
turnaround89   My chassis twisted hardcore   Feb 17 2010, 08:04 PM
nykthebartender   How much is way off? You can shim the door hinges ...   Feb 17 2010, 08:24 PM
scotty b   If the latch is out, how does the door line up wit...   Feb 17 2010, 08:26 PM
rick 918-S   :ttiwwp:   Feb 17 2010, 08:29 PM
yeahmag   Yeah... Take the striker out and close the door. S...   Feb 17 2010, 08:32 PM
J P Stein   I did something similar wheb installing my cage. W...   Feb 17 2010, 08:33 PM
SirAndy   went to test fit the passenger door and it won...   Feb 17 2010, 08:52 PM
bobhasissues   What were you welding? Engman kit Clamshells Other...   Feb 17 2010, 08:54 PM
McMark   :agree: we need a bunch more info/pics.   Feb 17 2010, 09:31 PM
turnaround89   I welded in clamshells over the longs and also put...   Feb 17 2010, 10:23 PM
davesprinkle   That sucks. The only real option is to cut a few ...   Feb 17 2010, 11:00 PM
turnaround89   the weirdest part is that the door hangs low at th...   Feb 17 2010, 11:25 PM
davesprinkle   the weirdest part is that the door hangs low at t...   Feb 17 2010, 11:41 PM
rick 918-S   Don't bend the door! Fix the chassis. If y...   Feb 18 2010, 08:21 AM
sean_v8_914   yup. show teh good chassis doctor your set up, bra...   Feb 18 2010, 09:30 AM
rick 918-S   I'm like 400 miles from you. (6 hrs) But I hav...   Feb 19 2010, 12:31 AM
ghuff   Pics. You can recover from this.   Feb 19 2010, 09:26 AM
Eric_Shea   http://www.914world.com/specs/bodydims.php Find o...   Feb 19 2010, 10:39 AM
Krank   Has anyone tried bonding stiffner panels in with t...   Feb 19 2010, 10:57 AM
yeahmag   That's a really interesting idea...   Feb 19 2010, 11:01 AM
kwales   Wouldn't do it. They are designed for adherin...   Feb 19 2010, 12:35 PM
Rod   I can't offer help as I haven't been here,...   Feb 19 2010, 02:41 PM
turnaround89   So the windshield frame has come back towards the ...   Feb 20 2010, 01:07 AM
Dave_Darling   Brad Mayeur at 914 Limited should have some idea o...   Feb 20 2010, 02:46 AM
rick 918-S   Brad Mayeur at 914 Limited should have some idea ...   Feb 20 2010, 07:31 AM
turnaround89   I have no problems towing the car to have it fixed...   Feb 20 2010, 11:24 AM
Eric_Shea   Very powerful hydraulics. You may still need to m...   Feb 20 2010, 11:35 AM
Eric_Shea   Also, that window frame doesn't really do ...   Feb 20 2010, 11:44 AM
gopack   I just did a Google search for "celette bench...   Feb 20 2010, 11:52 AM
jcambo7   I just did a Google search for "celette benc...   Feb 20 2010, 07:46 PM
rick 918-S   I just did a Google search for "celette benc...   Feb 20 2010, 08:23 PM
turnaround89   What makes the celette better than othe racks? Al...   Feb 21 2010, 10:24 PM
rick 918-S   What makes the celette better than othe racks? A...   Feb 21 2010, 10:46 PM
SirAndy   Lots more pix ... http://www.914world.com/bbs2/in...   Feb 21 2010, 11:15 PM
Jeff Hail   The shop in the photos is Ed Palmer's. Aka EPR...   Feb 21 2010, 11:30 PM
turnaround89   Sir andy - if you don't mind me asking, how mu...   Feb 21 2010, 11:32 PM
SirAndy   Sir andy - if you don't mind me asking, how m...   Feb 21 2010, 11:51 PM
turnaround89   does the place doing the chassis alignment rent th...   Feb 22 2010, 12:18 AM
SirAndy   does the place doing the chassis alignment rent t...   Feb 22 2010, 12:26 AM
rick 918-S   does the place doing the chassis alignment rent t...   Feb 22 2010, 12:56 AM
rick 918-S   does the place doing the chassis alignment rent ...   Feb 22 2010, 01:08 PM
SirAndy   Your inquiry just prompted me to do something I h...   Feb 22 2010, 01:16 PM
turnaround89   Found a body shop in my area with a celette bench,...   Feb 22 2010, 11:54 AM
rick 918-S   Found a body shop in my area with a celette bench...   Feb 22 2010, 12:12 PM
carr914   Turnaround, What happened to the pictures you were...   Feb 22 2010, 01:35 PM
turnaround89   the pictures were on an external hard drive which ...   Feb 22 2010, 02:23 PM
rick 918-S   the pictures were on an external hard drive which...   Feb 22 2010, 02:34 PM
turnaround89   right now were beginning to pull apart portions of...   Feb 22 2010, 04:47 PM
rick 918-S   I heard back from the shop. I really couldn't ...   Feb 22 2010, 05:51 PM
SirAndy   :WTF: I don't get it... Think about it ... ...   Feb 22 2010, 05:53 PM
dr914@autoatlanta.com   I braced the chassis, but obviously not enough. ...   Feb 22 2010, 06:14 PM
turnaround89   Id have to tow the car down to georgia, and that w...   Feb 22 2010, 06:38 PM
scotty b   Rick, how about getting access to the one you know...   Feb 23 2010, 06:57 PM
r_towle   B)-->
QUOTE(scotty b @ F...   Feb 23 2010, 10:47 PM
rick 918-S   B)--><div class='quotetop'>QUOTE...   Feb 24 2010, 12:04 AM
shaggy   how thick were the plates you welded on? regardles...   Feb 24 2010, 12:23 AM
rick 918-S   I'm near a deal on the Celette. :shades2:   Feb 25 2010, 06:28 PM
turnaround89   so heres the plan that we finally came up with. M...   Feb 25 2010, 07:04 PM
rick 918-S   so heres the plan that we finally came up with. ...   Feb 25 2010, 07:10 PM
sixnotfour   Rick , I hope you get a bench , AArron @ Fat Six h...   Feb 25 2010, 09:25 PM
9146986   I have an old Blackhawk bench, that I'm nearly...   Feb 26 2010, 09:03 AM
rick 918-S   I have an old Blackhawk bench, that I'm nearl...   Feb 26 2010, 10:17 AM
9146986   Thanks Rick! I felt kinda stupid after my pos...   Feb 26 2010, 12:40 PM
9146986   Didn't someone copy the fixture dimensions in ...   Feb 26 2010, 12:46 PM
SirAndy   Didn't someone copy the fixture dimensions in...   Feb 26 2010, 03:48 PM
turnaround89   update: the drivers side door fits properly, shimm...   Feb 26 2010, 03:56 PM
rick 918-S   update: the drivers side door fits properly, shim...   Feb 26 2010, 07:02 PM
turnaround89   that is exactly what my passenger side door looks ...   Feb 26 2010, 10:41 PM
rick 918-S   Here's another crude sketch. I assume you used...   Feb 26 2010, 11:21 PM
turnaround89   what your saying is fixing the door, should also f...   Feb 26 2010, 11:49 PM
rick 918-S   what your saying is fixing the door, should also ...   Feb 27 2010, 08:02 AM
turnaround89   I want to give a big thanks to everyone that helpe...   Mar 4 2010, 02:41 PM
rick 918-S   So tell us what you did! :sawzall: :smash: :...   Mar 4 2010, 03:57 PM
drive-ability   I second that above request :agree: :smash: Gre...   Mar 4 2010, 06:14 PM
turnaround89   i did exactly what rick told me to do, i used a bo...   Mar 4 2010, 06:21 PM
rick 918-S   i did exactly what rick told me to do, i used a b...   Mar 4 2010, 06:36 PM
Jon Fernandes   :trophy:   Mar 4 2010, 06:27 PM
turnaround89   Once again a BIG THANK YOU to everyone that has he...   Mar 4 2010, 08:10 PM
markb   :beer2:   Mar 4 2010, 10:18 PM
29 User(s) are reading this topic (29 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 10:56 PM
