> Coil overs, What do you think?
jmill
post Feb 26 2010, 11:36 AM
Green Hornet
I saw these from RSR and they look pretty sweet. Does anyone run these? I have 911 Boge struts with 3.5 spacing now. Do you know if the A caliper will bolt up to these? What weight spring do I need? It'll be on a street/track 6. I'd like it more track than street. Is there something better or cheaper out there?
BigD9146gt
post Feb 26 2010, 02:24 PM
OCD member
Region Association: Australia and New Zealand
the advantage/disadvantage of a coil over is:
-much lighter weight/ you are putting sprung weight on the strut itself
-huge amount of spring rates to choose from ( I think in either 5 or 10lb increments /... between hollow and solid, 10 options?
-can combine two springs, ie: tenders, helpers, heavy and light/ ... just what the torsion gives
-at the track quick change/not that much hard to change, but not much fine tuning either.
High end springs like Eibach cost upwards about $170 set depending on the size and length. However, I know you can get just as good quality smaller name brands for less than $80 set. Consider a couple sets of different spring rates for different driving scenarios will cost you about the same as a set of nice torsion bars.
If your looking for cool, your a tool... and should buy these cause every new must-have-sportscars have these equipped and every cool footballer has these on their Range Rovers. Even Paris Hilton runs coil overs on her new dogs! BUY THEM NOW! From Clint, he will set you up properly even though your goal is somewhat, well, I'm not sure what word to use... anyone?
EDIT: I am running 22mm hollow torsion bars... car has never driven in my hands. I have Boge A struts, Koni inserts... they were free.
jmill   Coil overs   Feb 26 2010, 11:36 AM
Chris Hamilton   Those are great struts since they have raised spin...   Feb 26 2010, 12:47 PM
BigD9146gt   Talk to Clint at Rebelracingproducts.com. Those lo...   Feb 26 2010, 02:04 PM
gopack   what is te advantage of coil over versus torsion b...   Feb 26 2010, 02:08 PM
Chris Hamilton   what is te advantage of coil over versus torsion ...   Feb 26 2010, 06:23 PM
SirAndy   The weight is just being moved from the bottom of...   Feb 26 2010, 09:40 PM
Chris Hamilton   The only real advantage i see is better spring ...   Feb 26 2010, 09:45 PM
tat2dphreak   :agree: probably all 3, def. cool factor. but I...   Feb 26 2010, 02:22 PM
BigD9146gt   the advantage/disadvantage of a coil over is: -muc...   Feb 26 2010, 02:24 PM
jmill   It wouldn't make sense to run these with torsi...   Feb 26 2010, 07:26 PM
Chris Hamilton   I run them on my blue car. With torsion bars. And...   Feb 26 2010, 09:30 PM
BigD9146gt   http://www.thextremeresources.com/boshi/images/ca...   Feb 27 2010, 12:34 PM
jmill   They are the cheapest way to get good front strut...   Feb 27 2010, 12:28 AM
Chris Hamilton   There is a difference between struts that have hig...   Feb 27 2010, 12:58 AM
BigD9146gt   I agree with Chris H, corner balancing on torsion ...   Feb 27 2010, 02:55 AM
jmill   I haven't decided on anything. Had my mind be...   Feb 27 2010, 11:54 AM
BigD9146gt   Ok, so why isn't it popular? Cost, torsion ...   Feb 27 2010, 12:28 PM
turboman808   Planning to get Von shocks with smart racing front...   Feb 27 2010, 12:04 PM
brant   a portion of a torsion bar is technically sprung a...   Feb 27 2010, 12:59 PM
sww914   More spring rate choices and easy rate changes, th...   Feb 28 2010, 10:48 AM
camaroz1985   I am making a cheap coilover setup for my car. ...   Mar 1 2010, 10:48 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 09:36 PM
