Stock Passenger Door Mirror, Where do they mount?? |
aircooledtechguy |
Feb 26 2010, 10:01 AM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I scored me a passenger door mirror today on CL. Now I need to get ready to mount it.
1. Do all the cars have the captured nuts under the door skin similar to the drivers door that just need to be drilled out through the skin?? If so, I assume drilling from the inside of the door out is the way to do this?? 2. If not and I will have to add my own nuts to the screws, does anyone have the correct location I will need to locate it so it's usable?? I know it needs to be aft of the drivers side a bit Thanks!! |
rick 918-S |
Feb 26 2010, 10:27 AM
Hey nice rack! -Celette Group: Members Posts: 20,507 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
There is a mirror installation thread here someplace. Check the search and see of you can find it. I used a punch through the captured nuts in the door to mark the location of the mirror. Once you have a light mark from the bottom you can re-punch it from the top. Drill carefully through the skin only.
plymouth37 |
Feb 26 2010, 12:08 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
I used a punch through the captured nuts in the door to mark the location of the mirror. Once you have a light mark from the bottom you can re-punch it from the top. Drill carefully through the skin only. (IMG:style_emoticons/default/agree.gif) |
johnnie5 |
Feb 26 2010, 03:22 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
I used a punch through the captured nuts in the door to mark the location of the mirror. Once you have a light mark from the bottom you can re-punch it from the top. Drill carefully through the skin only. (IMG:style_emoticons/default/agree.gif) I did this job a few months ago, fairly cut and dried. Be careful not to drill into the threads of the nut and not to let your drill bit wander on the door skin! |
Lo-Fi Version | Time is now: 18th June 2024 - 06:40 AM |
