jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Ok, so I want to fire the engine today on the test stand for the first time. I understand that I need to run it for 20mins at over 2500 rpm for cam/lifter break in.
I dont have a seperate tach, so what would be the min hook up to run long jumpers to the car, and use the in-dash tach? |
jeffdon |
Like i mentioned, turning it over without plugs i am getting 5-10psi oil pressure. Damn thing wont turn over with plugs. I suspect my starter may be below par. Thinking i might get an early 911 starter, as it looks like they have almost double the power.
I just hope i do not have a bearing thats installed wrong. Pretty sure I dont. Anyone know how much torque it would take to turn over an engine with new bearings, new pistons and cylinders? Without plugs, that is. |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Like i mentioned, turning it over without plugs i am getting 5-10psi oil pressure. Damn thing wont turn over with plugs. I suspect my starter may be below par. Thinking i might get an early 911 starter, as it looks like they have almost double the power. I just hope i do not have a bearing thats installed wrong. Pretty sure I dont. Anyone know how much torque it would take to turn over an engine with new bearings, new pistons and cylinders? Without plugs, that is. Sounds like a classic wire/connection problem. What are you using to try and turn the starter? jumper cables with a battery, or did you get the proper cables for it? |
jeffdon |
Like i mentioned, turning it over without plugs i am getting 5-10psi oil pressure. Damn thing wont turn over with plugs. I suspect my starter may be below par. Thinking i might get an early 911 starter, as it looks like they have almost double the power. I just hope i do not have a bearing thats installed wrong. Pretty sure I dont. Anyone know how much torque it would take to turn over an engine with new bearings, new pistons and cylinders? Without plugs, that is. Sounds like a classic wire/connection problem. What are you using to try and turn the starter? jumper cables with a battery, or did you get the proper cables for it? Jumper cables. Think properly cabling it will make that big a dif? |
underthetire |
Like i mentioned, turning it over without plugs i am getting 5-10psi oil pressure. Damn thing wont turn over with plugs. I suspect my starter may be below par. Thinking i might get an early 911 starter, as it looks like they have almost double the power. I just hope i do not have a bearing thats installed wrong. Pretty sure I dont. Anyone know how much torque it would take to turn over an engine with new bearings, new pistons and cylinders? Without plugs, that is. Sounds like a classic wire/connection problem. What are you using to try and turn the starter? jumper cables with a battery, or did you get the proper cables for it? Jumper cables. Think properly cabling it will make that big a dif? Huge difference. And remember, it's always the ground. |
jeffdon |
Allrighty, off the FLAPS for some proper cabling.
underthetire |
Lo-Fi Version | Time is now: 26th June 2024 - 02:15 AM |
