WTB NLA fuel line gaskets, 914 201 147 10 and 311 201 235 A |
mgphoto |
Feb 28 2010, 07:56 PM
"If there is a mistake it will find me" Group: Members Posts: 1,363 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello,
I am trying to find a reliable source for the NLA copper gaskets that are located between the fuel tank and the fuel line connections. They are part numbers: 311 201 235 A 914 201 147 10 I tried one source but they seem to be unable to supply the correct sizes, either the center hole is too big or the outer diameter is too small, both of which are causing dangerous gasoline leaks. Thanks, Mike |
detoxcowboy |
Feb 28 2010, 11:24 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
You will only ever find the small one in the correct size. Metric Copper Sealing Washers are available alot of places but your right the OD or the ID will always be off, So like you I could never find the perfect size so I made one out of one they are cheap so you can screw one up or two.. TIP of the day: Anneal Them same as for exhaust copper rings.. heat them up with a blow torch or your stove first let them cool off.. this softens them for a better seal..
Lo-Fi Version | Time is now: 26th September 2024 - 11:49 AM |
