Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
So, I need to see what people have done with the engine lid latch, computer and wires! I have the clutch, flywheel, TOB and internal oil cooler done.
I don't want to get into a discussion about if I need another cooler or not just the basic installation stuff. I will deal with the rest later! Thanks for anything you have! (IMG:style_emoticons/default/beerchug.gif) Jeff |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
Are you running the CIS system? You might want to consider rotating the injection 180 degrees on the motor. I've seen it done and you have to modify the engine shroud,but the injection fits much better in this orientation, also I think you can use an air box from an audi... hopefully someone has some photos or more info.
I ran a 2.7 CIS for awhile, we had to flip the fuel distributor and remove the engine latch, (other wise left it mostly stock) but after going thru this I would find some way to end up keeping the engine latch( like rotating the injection). |
Lo-Fi Version | Time is now: 26th June 2024 - 09:49 AM |
