Cheapsnake |
Member ![]() ![]() Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 ![]() |
After months of teardown, cleaning, machining, fabricating, replacing and tweaking I finally got to the point of lighting the fire. I did a bench start so I could locate and fix any bugs out in the open vs in the car. Turns out it started and ran so nicely it was almost anticlimatic. However, anybody that's ever done a first start after a rebuild, especially a highly modified rebuild knows what a gut-wrenching experience it is and what a thrill it is when it actually starts and runs!!!
OK, so here's the spec's: Rover 3.5 block and rotating assembly, 4.0 heads and headers (higher compression and better breathing), Crane 282* cam, Buick 215 oil pan, timing cover and intake manifold, Rochester Quadrajet carb, remote CSR water pump. Note that the distributor and coil are there just for the bench start. Once in the car an EDIS/Megajolt ignition system will take over the firing duties, saves a good 1" clearance between the firewall and distributor, plus it delivers much more accurate timing. Here goes: (IMG:http://i46.photobucket.com/albums/f123/Cheapsnake/th_rover.jpg) Tom |
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Love the "YEAH!! (IMG:style_emoticons/default/aktion035.gif) " at the end. Good work sounded sweet and started well - I changed the HGaskets on one of these for a friend the other day whilst in the car - god, you're lucky doing it on a stand (IMG:style_emoticons/default/headbang.gif)
Good solid engines - bizarre than an American is fitting a 'Rover' engine (nee Buick) - all I want is a small block Ford or Chevy to tinker with.. |
Cheapsnake |
Good solid engines - bizarre than an American is fitting a 'Rover' engine (nee Buick) - all I want is a small block Ford or Chevy to tinker with.. Sometimes life plays cruel jokes on us, but if you had the Rover and I had the SBC what fun would that be? (IMG:style_emoticons/default/beerchug.gif) Tom |
Lo-Fi Version | Time is now: 25th June 2024 - 10:46 PM |
