Rover V8 bench start - video, We have ignition! |
Cheapsnake |
Mar 3 2010, 09:08 AM
Member Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 |
After months of teardown, cleaning, machining, fabricating, replacing and tweaking I finally got to the point of lighting the fire. I did a bench start so I could locate and fix any bugs out in the open vs in the car. Turns out it started and ran so nicely it was almost anticlimatic. However, anybody that's ever done a first start after a rebuild, especially a highly modified rebuild knows what a gut-wrenching experience it is and what a thrill it is when it actually starts and runs!!!
OK, so here's the spec's: Rover 3.5 block and rotating assembly, 4.0 heads and headers (higher compression and better breathing), Crane 282* cam, Buick 215 oil pan, timing cover and intake manifold, Rochester Quadrajet carb, remote CSR water pump. Note that the distributor and coil are there just for the bench start. Once in the car an EDIS/Megajolt ignition system will take over the firing duties, saves a good 1" clearance between the firewall and distributor, plus it delivers much more accurate timing. Here goes: (IMG:http://i46.photobucket.com/albums/f123/Cheapsnake/th_rover.jpg) Tom |
Cheapsnake |
Mar 3 2010, 07:24 PM
Thanks guys, we V8 guys need a little victory every now and then to keep us going. I've done several projects before, including a Cobra replica, but nothing has frustrated (or satisfied) me as much as this V8 conversion. Everything is a prototype design. To that end, if anybody needs pics or other info on anything relating to the conversion, say the word.
Tom |
Lo-Fi Version | Time is now: 25th June 2024 - 10:45 PM |
