bluhun |
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California ![]() |
Sometime ago I posted a problem with severe brake squeal following installation of Porterfield R4S pads on my 914-6 conversion car. I'm running Boxster calipers up front and the PMB widened calipers in the rear.
I've been able to trace the problem to the right front caliper. Since the other three calipers don't squeal, I assume that there's some sort of alignment issue between the caliper/pad combo and rotor. However, the caliper didn't squeal before with the Textar pads. The right side also locks up before the left, with lots of tire skreech and smoke, but nothing from the driver's side. Are these two observations related? Any suggestions would be greatly appreciated! |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Porterfields are noisy ...
If one side locks up before the other, you have a problem, regardless of what pads you use. Could be sticky pistons. Sounds like a caliper rebuild may be in order ... My Porterfields: - Quiet when rolling - Noisy when the brakes are applied in a normal manner - Quiet again under hard braking (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 12:42 AM |
