FS: 914 Rear Race Calipers, ***No Handbrake Option*** |
Eric_Shea |
Nov 21 2009, 01:05 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Every now and again we get a pair of late 912 rear calipers in-house. These rare calipers share the 38mm piston diameter with the 914-6 and all 911's (for practical purposes) through 1983. These also have the same #31 pad size associated with the 914-6 and 911 calipers. So... larger pistons and larger pad size.
What are these good for? If you've moved to 5-lug up front and you're now using anything from an M-Caliper (stock 914-6), an S-Caliper (911S, RS, 930), an A-Caliper (911SC through 1983) or a Wide A-Caliper (911 Carrera) these would be a bolt on caliper that would retain the braking bias those cars were set up with (48mm pistons up front and 38mm pistons in the rear). These are true late 912 calipers vs. 911 rear M-Calipers. What's the difference? They don't have the 10mm spacers. They have the same Ribe R6 cap head fasteners just in the shorter length to accomodate the spacerless application. Because there's no spacers, these fit over a solid 914 or 914-6 rotor (keeps weight down). With the 3" mounting ear spacing, these bolt right on to a 914 rear control arm. ***There is no handbrake option if you install these. This is why they are recommended as race calipers only*** You can add a spot caliper or, install the early 911 handbrake assembly to your arms but, these are really a great solution for the track car that needs proper rear bias and a larger pad without worrying about the DMV and their rules and regulations. You'll probably want a 19mm MC as well. Comes with everything you need (pins springs and bleeders) with the exception of pads (we can help there too...) Our normal restoration price is $249.00 plus cores. These will sell fo $199.00 for the pair with no core required. Shipping is $9.85 Flat Rate to anywhere in the US. Ask for International shipping. Crappy picture below: |
koozy |
Mar 5 2010, 05:39 PM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I find that when I autocross and when I am on the track I am either on the gas or fill tilt boogie on the brakes. One thing I know for sure is I don't want the pressure regulator "shutting down" ANY of the brakes at ANY time under these driving conditions. No matter how well the thing is engineered, there are proper parts for each application and one should know what they are doing when messing with any of them. I, for instance, don't believe the stock pressure regulator is good for a race application. I don't need to know ALL the rates of grip for pads to know the difference of what works for me and what doesn't. If you don't do your own setup and know what is working for you and what doesn't, you need to have someone else tell you what to do. If you build, tune and test your own equipment then you can do the math yourself instead of relying on someone elses opinion of what is going to work for you.That's why I didn't list which compounds would work for any given situation. Because I don't know. You need to do some work to make that happen.
I do know that Dan is not the first one, nor is he the only one to do this succesfully. Many folks that race their cars tune brake bias with pads. Need proof... go to a GGR AX event and I'll show you. That said, if you do not do your own work or can not test and tune your own equipment then one of the few folks I would trust with my brakes is Eric. No one person can know everything and race applications are very car/driver specific so that throws a monkey wrench into the whole game. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:02 PM |
