buhs914 |
Not So Newbie ![]() ![]() Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region ![]() |
So i bought a new low tone horn because the previous horn sounded like a miniature train. I thought it would be a direct swap until i found that it had these
![]() they were powered by an air pump in the spare tire area that was wired to a relay right next to it.. WTF? i looked at the wiring diagram to see what wires actually go to the stock horn and i couldn't find those wires in my car.. i also find the wiring for the fog lights that i don't have (idk if those are supposed to be there or not).. could someone please post a picture of the stock horn with the wiring and relay. i need a reference. |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
The air pump would need to build pressure in order to function. So I would guess that the pump should be activated when the key is turned on. It would then build enough pressure and shut off. When the horn is pressed the ground from the original horn loop is completed and activates a relay near the pump that releases the compressed air to the horns! (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 10:30 PM |
