jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I was wondering how hard it should be to rotate the A-arm when the strut is disconneted? I put new poly bushings in from Pelican when I restored the car a couple of years ago. I was updating some front suspension bits and when I disconnect the strut I have to pry the a-arm down.
Shouldn't it rotate fairly free? Are the bushings maybe not concentric? Just curiuos as to whether others have run into this and what the possible fixes might be. Don't really have a budget for the poly bronze bearings I have seen advertised. |
jmargush |
Thanks
So is there a concensous that one could modify the od of the Bushing once it is installed in the outer sleeve that the od could be reamed to the right diameter? or is it better to just go with the poly Bronze ? |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Thanks So is there a concensous that one could modify the od of the Bushing once it is installed in the outer sleeve that the od could be reamed to the right diameter? or is it better to just go with the poly Bronze ? Some people have been satisfied with using the polygraphite bushings. It is possible to "adjust" the id of them to provide free motion of the a-arm. However, the polygraphite doesn't ream or sand easily. It tends to smear instead of cut. There's a reason they are so inexpensive (cheap). |
Lo-Fi Version | Time is now: 26th June 2024 - 09:52 AM |
