rev limiter failure? |
dflesburg |
Mar 8 2010, 09:07 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
we had a breaking throttle cable this weekend on the 2.0 four.
We did have a rev limiting rotor. motor reved up to around 7000 not sure why? do these rev limiters wear out? Cut out is supposed to be like 5500 |
Cap'n Krusty |
Mar 8 2010, 01:24 PM
Actually, there's no contact for "open" The rotor contains a spring loaded piece between the center and the rotor tip. When the revs rise to a set point, the spring is overcome and the connection is broken. Remember, too, that the rev limiter only affects the electrical system; If you downshift into the wrong gear, the engine will rev as high as the gearing wants it to go.
The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 10:29 AM |
