EJP914 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 ![]() |
Does anyone have a fix for repairing the tab or clip on the backside of the horn pad in the center of the steering wheel? I found the wire that comes thru the column laying in the center of the wheel hub with the clip stuck in it - broken off from where it attaches. Would drilling a hole in the aluminum plate and putting a bolt and nut on it to hold the wire work? Car is a '74
Maybe someone has a better idea? Thanks for the advice. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
You can get these types of connectors and rivet it to the plate (it's steel). McMaster-Carr has 'em (thanks for the pic) but only in packs of 100. Try RadioShack.
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 29th June 2024 - 09:49 AM |
