How bad is your heat?, Am I chasing a lost cause?? |
wayne1234 |
Mar 10 2010, 05:39 PM
Member Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
So I took off the hearter parts of my parts car and cleaned them all up and painted everything did the drivers side and decided to try it out..... (IMG:style_emoticons/default/sad.gif) tempeture was about 60 outside last night and after running a few minutes the vent was putting out a weak 72 hardley any air movement. the flapper bos is working and in good condition and the dual fan blows out a fair amount of air, but it doesnt seem to make it up front... on chilly mornings and evenings I want some heat and defrost... this wont cut it in my opinion... what else has been done??? I had a crazy idea of a power inverter, and hair dryers behind the speakers, anyone done anything like this??? I have seen 12 volt hair dryers... what else has been done????? or what am I doing wrong ???? I know I have read many complaints about the heat but I had no idea it was that bad...
Kirmizi |
Mar 10 2010, 08:14 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
I believe the auxillary fan runs off the same fuse on the relay board as the fuel pump. IIRC it's the rear fuse. Does the blower motor work if you apply 12v?
Mike |
Lo-Fi Version | Time is now: 25th June 2024 - 06:18 PM |
