wayne1234 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None ![]() |
So I took off the hearter parts of my parts car and cleaned them all up and painted everything did the drivers side and decided to try it out..... (IMG:style_emoticons/default/sad.gif) tempeture was about 60 outside last night and after running a few minutes the vent was putting out a weak 72 hardley any air movement. the flapper bos is working and in good condition and the dual fan blows out a fair amount of air, but it doesnt seem to make it up front... on chilly mornings and evenings I want some heat and defrost... this wont cut it in my opinion... what else has been done??? I had a crazy idea of a power inverter, and hair dryers behind the speakers, anyone done anything like this??? I have seen 12 volt hair dryers... what else has been done????? or what am I doing wrong ???? I know I have read many complaints about the heat but I had no idea it was that bad...
wayne1234 |
yep blower works I had it directly to battery for testing... ok found the wiring diagram on the board and the relay clicks if I pull the lever... but I think I should have power at terminal #11 I don't???? if I pull the relay there is power on the socket.. and the relay clicks but no power to terminal 11 ... What am I missing? (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 05:34 PM |
