wayne1234 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None ![]() |
So I took off the hearter parts of my parts car and cleaned them all up and painted everything did the drivers side and decided to try it out..... (IMG:style_emoticons/default/sad.gif) tempeture was about 60 outside last night and after running a few minutes the vent was putting out a weak 72 hardley any air movement. the flapper bos is working and in good condition and the dual fan blows out a fair amount of air, but it doesnt seem to make it up front... on chilly mornings and evenings I want some heat and defrost... this wont cut it in my opinion... what else has been done??? I had a crazy idea of a power inverter, and hair dryers behind the speakers, anyone done anything like this??? I have seen 12 volt hair dryers... what else has been done????? or what am I doing wrong ???? I know I have read many complaints about the heat but I had no idea it was that bad...
wayne1234 |
I'm going to try the paint cap thing tomorrow, It was the damn relay socket if i wiggle the relay or take it almost out it would fire up the blower,, I unhooked the heat hoses at the speaker grill and used a shop vac on blow, and blew both directions to the engine bay with the flex hoses un hooked, and up to the dash, it was fairly clean only dust came out... nothing big... then we hooked up the lines again and hooked the shop vac to the blower hoses and found as many leaks as we could and used high temp sillycone Also I ran a bolt through the rear of the heat exchanger to clamp it down to the exhaust pipes, we had minimal leaks,, made sure the lever was fully opening up the boxes.. Then we hooked back up the blower and hardly any air flow , then we fired up the engine even at 2500 rpm hardley any air coming through,,,, (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/headbang.gif) there is something I am missing
Lo-Fi Version | Time is now: 25th June 2024 - 05:52 PM |
