How bad is your heat?, Am I chasing a lost cause?? |
wayne1234 |
Mar 10 2010, 05:39 PM
Member Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
So I took off the hearter parts of my parts car and cleaned them all up and painted everything did the drivers side and decided to try it out..... (IMG:style_emoticons/default/sad.gif) tempeture was about 60 outside last night and after running a few minutes the vent was putting out a weak 72 hardley any air movement. the flapper bos is working and in good condition and the dual fan blows out a fair amount of air, but it doesnt seem to make it up front... on chilly mornings and evenings I want some heat and defrost... this wont cut it in my opinion... what else has been done??? I had a crazy idea of a power inverter, and hair dryers behind the speakers, anyone done anything like this??? I have seen 12 volt hair dryers... what else has been done????? or what am I doing wrong ???? I know I have read many complaints about the heat but I had no idea it was that bad...
Gint |
Mar 11 2010, 07:21 AM
Mike Ginter Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) with the others about 914 heat. If you drive around at 3000rpm, it will toast you out. Especially if you have a window cracked open to provide airflow. You have to remove all blockages as well as air leaks in your heat system. I would (and did) do that first.
IIWY, I would forget about that silly little electric blower motor for the time being. It will only do any good at idle speeds or just above. Once you get the engine running at 2500 rpm and over, the engine fan will overcome anything the pathetic little electric blower motor will provide anyway. My blower doesn't work and I never bothered to figure out why because they are pretty much worthless anyway. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:53 PM |
