mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Hello,
I am trying to find a reliable source for the NLA copper gaskets that are located between the fuel tank and the fuel line connections. They are part numbers: 311 201 235 A 914 201 147 10 I tried one source but they seem to be unable to supply the correct sizes, either the center hole is too big or the outer diameter is too small, both of which are causing dangerous gasoline leaks. Thanks, Mike |
mgphoto |
Hello again,
I received the third set of fuel tank gaskets from AA, (I am including a photo). As you can see there is a difference in size for the outer diameter, when placed on the fuel line there is a wide gap which does not cover the full width of the line, (I am including a second photo of that). I got in touch with a local guy who does metal work, mostly jewelry, he said he might be able to duplicate the gaskets. Thanks, Mike ![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 11:32 PM |
