904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,119 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
While trying to make the jigs to drill my heads for twin plugs I ran into a
major problem. Where is the plug going to be located on the bottom of the head. I made up this jig to located where the plug will be located. Angle jig ![]() Test jig installed ![]() Installed ![]() Bottom view ![]() |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
The heads will require lots of welding to accomodate the second set of plugs. Having done this to several pairs I can tell you from experience that it is a lot of work. Like Jake said there is a reason that it is expensive.
Good luck Larry! |
Lo-Fi Version | Time is now: 25th June 2024 - 05:57 PM |
